Salta al contenuto principale
Dell Inspiron 3847 RAM Stick Replacement
Cosa ti serve
  1. Dell Inspiron 3847 RAM Stick Replacement, RAM Stick: passo 1, immagine 1 di 1
    • Shut off and power down the PC by turning the switch to the off position, located on the back of the PC.
    • Unplug the power cable and remove any and all peripherals connected to PC.
  2. Dell Inspiron 3847 RAM Stick Replacement: passo 2, immagine 1 di 3 Dell Inspiron 3847 RAM Stick Replacement: passo 2, immagine 2 di 3 Dell Inspiron 3847 RAM Stick Replacement: passo 2, immagine 3 di 3
    • Lay your PC flat on its side with the 'Inspiron' Logo facing up.
    • Remove the two Phillips #0 screws from the back side of panel.
    • Slide the side panel off completely.
  3. Dell Inspiron 3847 RAM Stick Replacement: passo 3, immagine 1 di 2 Dell Inspiron 3847 RAM Stick Replacement: passo 3, immagine 2 di 2
    • Gently press down the flaps located on each end of the RAM slots. Remove the RAM stick(s) from the motherboard.
    • Repeat this step for each stick of RAM.
    • The flaps may be stiff when pressing down. Be careful not to use too much force if the RAM stick doesn't come loose.
  4. Dell Inspiron 3847 RAM Stick Replacement: passo 4, immagine 1 di 3 Dell Inspiron 3847 RAM Stick Replacement: passo 4, immagine 2 di 3 Dell Inspiron 3847 RAM Stick Replacement: passo 4, immagine 3 di 3
    • Align the new memory sticks with the memory slots.
    • Gently press down until a “CLICK” sound is made and flaps are pointing upwards.
    • Repeat this step for each stick of RAM you want to install.
  5. Dell Inspiron 3847 RAM Stick Replacement: passo 5, immagine 1 di 3 Dell Inspiron 3847 RAM Stick Replacement: passo 5, immagine 2 di 3 Dell Inspiron 3847 RAM Stick Replacement: passo 5, immagine 3 di 3
    • Slide the side panel back into position and screw in with the same screws from Step #2.
    • Plug all peripherals into the PC and switch it back on.
    • Boot up the computer. If no errors appear, then installation is complete!
Conclusione
To check if your RAM is installed correctly, Right-click on My PC, Click Properties, and check Installed Memory under the System heading.
Maninder
Membro da: 05/11/20
171 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 37
Tutti i Tempi: 797
