Salta al contenuto principale
Dell Inspiron 3520 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 3520 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 3520 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Keyboard Replacement: passo 2, immagine 1 di 3 Dell Inspiron 3520 Keyboard Replacement: passo 2, immagine 2 di 3 Dell Inspiron 3520 Keyboard Replacement: passo 2, immagine 3 di 3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 2 Dell Inspiron 3520 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 Keyboard Replacement: passo 4, immagine 1 di 1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 Keyboard Replacement: passo 5, immagine 1 di 2 Dell Inspiron 3520 Keyboard Replacement: passo 5, immagine 2 di 2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
Conclusione
Altre 7 persone hanno completato questa guida.
Ian
Membro da: 01/30/15
1.557 Reputazione
5 Guide realizzate
USF Tampa, Team 16-2, Watkins Winter 2015 Membro di USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Membri
5 Guide realizzate
Un commento
Hi, any ideas why a NEW keyboard still wouldn't work after installing it? The ribbon was connected properly, it’s the right keyboard, and I made sure the driver was updated. Any help would be greatly appreciated. Started a new job and my keyboard went to $@$* in the first week. Can’t really afford to buy a new laptop this weekend. It works with an external USB keyboard so it’s probably not a software issue… I think?
Alittle advice would be greatly appreciated. Thanks!
Stumpedu - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 42
Tutti i Tempi: 6,386
