Introduzione
Is your device experiencing problems with holding a charge or turning on? Consider using this guide to replace the battery in your device.
Cosa ti serve
Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
Flip the device over so the backside is facing you.
Remove the three 4mm screws holding battery in place using the Phillips #0 screwdriver.
Altre 2 persone hanno completato questa guida.
Un commento
Apparently the battery screws on mine all have red thread lock on them, meaning they will not come out and I fear I may end up stripping them if I’m not careful, I got one out, which his how I know they used red thread lock. Blue would have been sufficient
