Introduzione
If your Dell Inspiron (17R-N7010) is easily overheating or you don’t hear the fan running when it normally would be, it is time to replace the fan, and this guide will demonstrate how to do so.
The fan protects your computer from overheating and potentially damaging internal components. It is essential that this part be working correctly to lengthen the life of your computer.
Cosa ti serve
Flip over the laptop so the back is facing upwards.
Locate the battery compartment.
Remove the four screws from the back panel.
Flip the laptop over and open it to view the keyboard.
Disconnect the keyboard from the laptop by lifting up the latch holding the ribbon cable in place.
Locate the fan at the top left corner.
Remove the fan by disconnecting the coupled wires from the white port.
Disconnect the wire strip by lifting up the latch holding the wire in place.
Unscrew the remaining two screws.
Remove the fan.
