Salta al contenuto principale
Introduzione
You may want to remove the hard drive to upgrade to a higher capacity drive or if your files have become corrupted and unrecoverable.
Parti
Nessuna parte specificata.
  1. Unplug the laptop before changing the battery to avoid electric shock. Place the laptop on a flat stable surface.
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Locate the battery lock switch. Slide the lock switch to the left (away from the lock symbol).
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. Kit di riparazione per Android
    A new screen or battery is one kit away.
    Acquista ora
    Acquista ora
  4. Remove the two 1mm double wide Phillips #00 screws. Pull the hard drive away from the laptop.
    • Remove the two 1mm double wide Phillips #00 screws.
    • Pull the hard drive away from the laptop.
  5. Keep all screws in a safe place. You may need to use them for your new hard drive. Remove the two #00 1mm screws on both sides of the hard drive.
    • Keep all screws in a safe place. You may need to use them for your new hard drive.
    • Remove the two #00 1mm screws on both sides of the hard drive.
    • Pull the hard drive cover away from the hard drive and set the cover aside.
Conclusione
Altre 2 persone hanno completato questa guida.
Tina Rickard
Membro da: 07/04/2014
717 Reputazione
5 Guide realizzate
Cal Poly, Team 6-3, Forte Spring 2014 Membro di Cal Poly, Team 6-3, Forte Spring 2014
CPSU-FORTE-S14S6G3
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 48
Tutti i Tempi: 7,039
