Salta al contenuto principale
Dell Inspiron 1721 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 1721 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 1721 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Keyboard Replacement, Hinge Plate Cover: passo 2, immagine 1 di 3 Dell Inspiron 1721 Keyboard Replacement, Hinge Plate Cover: passo 2, immagine 2 di 3 Dell Inspiron 1721 Keyboard Replacement, Hinge Plate Cover: passo 2, immagine 3 di 3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 3 Dell Inspiron 1721 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 3 Dell Inspiron 1721 Keyboard Replacement, Keyboard: passo 3, immagine 3 di 3
    • Remove four 3mm Phillips #1 screws from the top of the keyboard.
    • Use an iFixit opening tool to slide the keyboard upwards toward the display.
    • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 248
