Salta al contenuto principale
Dell Inspiron 1721 Hinge Plate Cover Replacement
Cosa ti serve
  1. Dell Inspiron 1721 Hinge Plate Cover Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 1721 Hinge Plate Cover Replacement, Battery: passo 1, immagine 2 di 2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: passo 2, immagine 1 di 3 Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: passo 2, immagine 2 di 3 Dell Inspiron 1721 Hinge Plate Cover Replacement, Hinge Plate Cover: passo 2, immagine 3 di 3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 156
