Salta al contenuto principale
Dell Inspiron 1721 Back Cover Replacement
Cosa ti serve
  1. Dell Inspiron 1721 Back Cover Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 1721 Back Cover Replacement, Battery: passo 1, immagine 2 di 2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Back Cover Replacement, Hinge Plate Cover: passo 2, immagine 1 di 3 Dell Inspiron 1721 Back Cover Replacement, Hinge Plate Cover: passo 2, immagine 2 di 3 Dell Inspiron 1721 Back Cover Replacement, Hinge Plate Cover: passo 2, immagine 3 di 3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 Back Cover Replacement, Display Assembly: passo 3, immagine 1 di 2 Dell Inspiron 1721 Back Cover Replacement, Display Assembly: passo 3, immagine 2 di 2
    • Loosen the two captive Phillips #0 screws.
    • Remove the cover.
  4. Dell Inspiron 1721 Back Cover Replacement: passo 4, immagine 1 di 1
    • Disconnect the antenna connectors from the WLAN card.
  5. Dell Inspiron 1721 Back Cover Replacement: passo 5, immagine 1 di 3 Dell Inspiron 1721 Back Cover Replacement: passo 5, immagine 2 di 3 Dell Inspiron 1721 Back Cover Replacement: passo 5, immagine 3 di 3
    • Remove the 3mm Phillips #0 screw securing the connector to the case ground.
    • Disconnect the display connector.
    • Disconnect the second connector, then remove the cable from the base.
  6. Dell Inspiron 1721 Back Cover Replacement: passo 6, immagine 1 di 3 Dell Inspiron 1721 Back Cover Replacement: passo 6, immagine 2 di 3 Dell Inspiron 1721 Back Cover Replacement: passo 6, immagine 3 di 3
    • Remove the display cable from the palm rest.
    • Use a spudger to carefully pull the antenna wires through to front of the device.
  7. Dell Inspiron 1721 Back Cover Replacement: passo 7, immagine 1 di 2 Dell Inspiron 1721 Back Cover Replacement: passo 7, immagine 2 di 2
    • Remove the two 3.5 mm Phillips screws that hold the display assembly in place.
    • Lift the assembly straight up to separate it from the body of the device.
  8. Dell Inspiron 1721 Back Cover Replacement, Back Cover: passo 8, immagine 1 di 1
    • Disconnect the touch pad connector.
  9. Dell Inspiron 1721 Back Cover Replacement: passo 9, immagine 1 di 3 Dell Inspiron 1721 Back Cover Replacement: passo 9, immagine 2 di 3 Dell Inspiron 1721 Back Cover Replacement: passo 9, immagine 3 di 3
    • Lay the device flat and remove the 17 7mm Phillips #0 screws.
    • Use an iFixit opening tool to separate the back cover.
    • Remove the back cover.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 225
