Introduzione
This guide is for the Dell Inspiron 17" 7786 2-in-1 internal battery replacement.
Over time, maximum power on the batteries will decrease or even begin developing issues for the user. It may be necessary to replace the battery if it has not been changed in some time. If your battery does not seem to keep or hold power even after a charging, the battery may need to be replaced.
Click here to validate and compare symptoms.
Before using this guide, please check to make sure there is no debris in the charging port and that your charger is working correctly.
This guide instructs how to open the device's shell and properly remove the battery. Replacement of this component is not too complex, nor does it take much time to do so.
Cosa ti serve
Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
Detach the tab connecting the battery to the system board using your fingers or a pair of tweezers.
Peel off the adhesive tab holding the cable to the device.
Altre 2 persone hanno completato questa guida.
5 Commenti
Looks good , where I can get Battery Replacement from ?
Hello! You can look at newegg com, amazon.com or ebay.com. That's where you can get a bunch of great used parts!
THANK YOU, THANK YOU, THANK YOU! I replaced the battery following your instructions. The only thing I did differently is that I couldn't get the plug out with the battery still screwed down, so I unscrewed the battery then unplugged it. After unplugging, then I held down the power key for a few seconds to discharge before plugging in the new battery and screwing it down. My computer will be like new now! Blessings to all of you at IFixIt!
I bought my new replacement battery from the store at IFixIt.com.
You're welcome! I'm glad our project could help you!
