Salta al contenuto principale
Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement
Cosa ti serve
  1. Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement, Base Cover: passo 1, immagine 1 di 2 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement, Base Cover: passo 1, immagine 2 di 2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: passo 2, immagine 1 di 2 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: passo 2, immagine 2 di 2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: passo 3, immagine 1 di 3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: passo 3, immagine 2 di 3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: passo 3, immagine 3 di 3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: passo 4, immagine 1 di 3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: passo 4, immagine 2 di 3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: passo 4, immagine 3 di 3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement, Internal Battery: passo 5, immagine 1 di 3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement, Internal Battery: passo 5, immagine 2 di 3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement, Internal Battery: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Detach the tab connecting the battery to the system board using your fingers or a pair of tweezers.
    • Peel off the adhesive tab holding the cable to the device.
  6. Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: passo 6, immagine 1 di 1
    • Flip the device over. Press and hold the power button for a few seconds to discharge any leftover electrical current.
    • You may leave the screen open if further repair is needed, or close it if you are only replacing the battery.
  7. Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: passo 7, immagine 1 di 3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: passo 7, immagine 2 di 3 Dell Inspiron 17" 7786 2-in-1 Internal Battery Replacement: passo 7, immagine 3 di 3
    • Dell's official service manual does not mention of the 5th screw located near the middle edge of the battery closer to the touchpad.
    • Flip the device back over.
    • Remove five 3 mm screws that are securing the battery using a Phillips #0 screwdriver.
    • Lift the battery upwards to remove it completely.
Conclusione
Altre 2 persone hanno completato questa guida.
Antonio Franco
Membro da: 08/25/22
1.025 Reputazione
10 Guide realizzate
Gateway, Team 1-3, Class Fall 2022 Membro di Gateway, Team 1-3, Class Fall 2022
GCC-CLASS-F22S1G3
4 Membri
15 Guide realizzate
5 Commenti
Looks good , where I can get Battery Replacement from ?
ilan magen - Replica
Hello! You can look at newegg com, amazon.com or ebay.com. That's where you can get a bunch of great used parts!
Delia Padilla -
THANK YOU, THANK YOU, THANK YOU! I replaced the battery following your instructions. The only thing I did differently is that I couldn't get the plug out with the battery still screwed down, so I unscrewed the battery then unplugged it. After unplugging, then I held down the power key for a few seconds to discharge before plugging in the new battery and screwing it down. My computer will be like new now! Blessings to all of you at IFixIt!
I bought my new replacement battery from the store at IFixIt.com.
Brenda McCurdy Cable - Replica
You're welcome! I'm glad our project could help you!
Delia Padilla -
After I've ''discharged any leftover power" by holding the power button down. What do I do ? Do I leave it until the laptop turns off by itself ? Or do I hold down the power button to force shutdown ?
Kalafinwë - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 48
Tutti i Tempi: 612
