Salta al contenuto principale
Dell Inspiron 17" 7786 2-in-1 Fan Replacement
Cosa ti serve
  1. Dell Inspiron 17" 7786 2-in-1 Fan Replacement, Base Cover: passo 1, immagine 1 di 2 Dell Inspiron 17" 7786 2-in-1 Fan Replacement, Base Cover: passo 1, immagine 2 di 2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Fan Replacement: passo 2, immagine 1 di 2 Dell Inspiron 17" 7786 2-in-1 Fan Replacement: passo 2, immagine 2 di 2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Fan Replacement: passo 3, immagine 1 di 3 Dell Inspiron 17" 7786 2-in-1 Fan Replacement: passo 3, immagine 2 di 3 Dell Inspiron 17" 7786 2-in-1 Fan Replacement: passo 3, immagine 3 di 3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Fan Replacement: passo 4, immagine 1 di 3 Dell Inspiron 17" 7786 2-in-1 Fan Replacement: passo 4, immagine 2 di 3 Dell Inspiron 17" 7786 2-in-1 Fan Replacement: passo 4, immagine 3 di 3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Fan Replacement, Fan: passo 5, immagine 1 di 2 Dell Inspiron 17" 7786 2-in-1 Fan Replacement, Fan: passo 5, immagine 2 di 2
    • Gently remove the I/O cable.
  6. Dell Inspiron 17" 7786 2-in-1 Fan Replacement: passo 6, immagine 1 di 2 Dell Inspiron 17" 7786 2-in-1 Fan Replacement: passo 6, immagine 2 di 2
    • Remove the fan cable from the motherboard.
  7. Dell Inspiron 17" 7786 2-in-1 Fan Replacement: passo 7, immagine 1 di 1
    • Remove two 3 mm screws that secure the fan using a Phillips #0 screwdriver.
  8. Dell Inspiron 17" 7786 2-in-1 Fan Replacement: passo 8, immagine 1 di 2 Dell Inspiron 17" 7786 2-in-1 Fan Replacement: passo 8, immagine 2 di 2
    • There is a little piece of tape/sticker on the fan that connects it to the heat sink. Gently remove this.
    • Lift the fan off the palm rest assembly.
Conclusione
Gateway, Team 1-3, Class Fall 2022 Membro di Gateway, Team 1-3, Class Fall 2022
GCC-CLASS-F22S1G3
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 27
Tutti i Tempi: 253
