Introduzione
This is the replacement guide for the Dell Inspiron 17-7737 RAM. RAM, or random access memory, is the fastest and most depended-on component for high-speed computing inside a computer and problems with it can expose a computer's operation to being extremely volatile.
Disclaimer: Please be cautious in regard to swollen batteries, as battery acid is extremely toxic to humans, any puncture or leak can be a major issue if left unnoticed or unresolved.
Cosa ti serve
Close the display and turn the computer over.
Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
Pry the memory module's cover off of the computer's base using an opening tool.
