Salta al contenuto principale
Dell Inspiron 17-7737 Hard Disk Drive Replacement
Cosa ti serve
  1. Dell Inspiron 17-7737 Hard Disk Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 Hard Disk Drive Replacement: passo 2, immagine 1 di 3 Dell Inspiron 17-7737 Hard Disk Drive Replacement: passo 2, immagine 2 di 3 Dell Inspiron 17-7737 Hard Disk Drive Replacement: passo 2, immagine 3 di 3
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 Hard Disk Drive Replacement: passo 3, immagine 1 di 1
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 Hard Disk Drive Replacement: passo 4, immagine 1 di 2 Dell Inspiron 17-7737 Hard Disk Drive Replacement: passo 4, immagine 2 di 2
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
  5. Dell Inspiron 17-7737 Hard Disk Drive Replacement, Hard Disk Drive: passo 5, immagine 1 di 1
    • Remove the four 2.5 mm hard drive bay screws using a Phillips #1 screwdriver.
  6. Dell Inspiron 17-7737 Hard Disk Drive Replacement: passo 6, immagine 1 di 1
    • Using the pull tab, lift the hard drive assembly off of the body.
  7. Dell Inspiron 17-7737 Hard Disk Drive Replacement: passo 7, immagine 1 di 2 Dell Inspiron 17-7737 Hard Disk Drive Replacement: passo 7, immagine 2 di 2
    • Disconnect the hard drive cable and lift it out of the computer case.
  8. Dell Inspiron 17-7737 Hard Disk Drive Replacement: passo 8, immagine 1 di 1
    • Remove a total of four screws that secure the cage to the assembly.
    • There are two screws on either side of the cage.
  9. Dell Inspiron 17-7737 Hard Disk Drive Replacement: passo 9, immagine 1 di 1
    • Using the pull tab, lift the hard drive out of the cage.
Conclusione
Mark Batista
Membro da: 03/16/23
457 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 39
Tutti i Tempi: 263
