Salta al contenuto principale
Dell Inspiron 17-7737 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 17-7737 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 Battery Replacement: passo 2, immagine 1 di 3 Dell Inspiron 17-7737 Battery Replacement: passo 2, immagine 2 di 3 Dell Inspiron 17-7737 Battery Replacement: passo 2, immagine 3 di 3
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 Battery Replacement: passo 3, immagine 1 di 1
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 Battery Replacement: passo 4, immagine 1 di 2 Dell Inspiron 17-7737 Battery Replacement: passo 4, immagine 2 di 2
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
Conclusione
Mark Batista
Membro da: 03/16/23
457 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 34
Tutti i Tempi: 267
