Salta al contenuto principale
Dell Inspiron 17-5749 Wireless Card Replacement
Cosa ti serve
  1. Dell Inspiron 17-5749 Wireless Card Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 17-5749 Wireless Card Replacement, Battery: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Wireless Card Replacement: passo 2, immagine 1 di 2 Dell Inspiron 17-5749 Wireless Card Replacement: passo 2, immagine 2 di 2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Wireless Card Replacement, Back Cover: passo 3, immagine 1 di 3 Dell Inspiron 17-5749 Wireless Card Replacement, Back Cover: passo 3, immagine 2 di 3 Dell Inspiron 17-5749 Wireless Card Replacement, Back Cover: passo 3, immagine 3 di 3
    • Remove the two 5.5mm screws that secure the base cover to the computer's base.
    • Using the plastic opening tool, carefully pry open the base cover starting from the center.
    • Lift the base cover upwards to remove and set it aside.
  4. Dell Inspiron 17-5749 Wireless Card Replacement, Wireless Card: passo 4, immagine 1 di 3 Dell Inspiron 17-5749 Wireless Card Replacement, Wireless Card: passo 4, immagine 2 di 3 Dell Inspiron 17-5749 Wireless Card Replacement, Wireless Card: passo 4, immagine 3 di 3
    • Disconnect the antenna cables from the wireless card.
    • Push the securing tab to release the wireless card.
    • Slide the wireless card out of the wireless-card slot.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 218
