Salta al contenuto principale
Dell Inspiron 17-5749 Optical Drive Replacement
Cosa ti serve
  1. Dell Inspiron 17-5749 Optical Drive Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 17-5749 Optical Drive Replacement, Battery: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Optical Drive Replacement: passo 2, immagine 1 di 2 Dell Inspiron 17-5749 Optical Drive Replacement: passo 2, immagine 2 di 2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: passo 3, immagine 1 di 3 Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: passo 3, immagine 2 di 3 Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: passo 3, immagine 3 di 3
    • Remove the 5.5mm screw that secures the optical-drive assembly to the computer base
    • Using your fingertips, slide the optical-drive assembly out of the optical drive bay.
  4. Dell Inspiron 17-5749 Optical Drive Replacement: passo 4, immagine 1 di 3 Dell Inspiron 17-5749 Optical Drive Replacement: passo 4, immagine 2 di 3 Dell Inspiron 17-5749 Optical Drive Replacement: passo 4, immagine 3 di 3
    • This step is only needed if replacing the optical drive.
    • Remove the 2.5mm screw that secures the optical-drive bracket to the optical drive assembly.
    • Remove the optical-drive bracket from the optical-drive assembly.
    • Carefully pull the optical-drive bezel and remove it from the optical drive.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 131
