Salta al contenuto principale
Dell Inspiron 17-3721 Optical Drive Replacement
Cosa ti serve
  1. Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: passo 1, immagine 1 di 2 Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: passo 1, immagine 2 di 2
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Optical Drive Replacement: passo 2, immagine 1 di 2 Dell Inspiron 17-3721 Optical Drive Replacement: passo 2, immagine 2 di 2
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
  3. Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: passo 3, immagine 1 di 3 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: passo 3, immagine 2 di 3 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: passo 3, immagine 3 di 3
    • Remove the four 6 mm PH1 Philips head screws under the keyboard.
    • Carefully pop off the cover using the plastic opening tools and your hands.
  4. Dell Inspiron 17-3721 Optical Drive Replacement: passo 4, immagine 1 di 3 Dell Inspiron 17-3721 Optical Drive Replacement: passo 4, immagine 2 di 3 Dell Inspiron 17-3721 Optical Drive Replacement: passo 4, immagine 3 di 3
    • Remove the 4 mm PH1 Philips head screw holding down the optical drive.
    • Use your hand to slide the drive out of the device.
Conclusione
Kevin Prairie
Membro da: 03/20/18
445 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 303
