Salta al contenuto principale
Dell Inspiron 17-3721 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 17-3721 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 Dell Inspiron 17-3721 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Keyboard Replacement: passo 2, immagine 1 di 2 Dell Inspiron 17-3721 Keyboard Replacement: passo 2, immagine 2 di 2
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
Conclusione
Kevin Prairie
Membro da: 03/20/18
445 Reputazione
4 Guide realizzate
Un commento
Wow that was easy! Thanks :D
Isaac Pettis - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 414
