Salta al contenuto principale
Dell Inspiron 17-3721 CMOS Battery Replacement
Cosa ti serve
  1. Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: passo 1, immagine 1 di 3 Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: passo 1, immagine 2 di 3 Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: passo 1, immagine 3 di 3
    • Remove the two 6.5 mm PH1 Philips head screws on the back panel.
    • Lift up the small panel from the top, using the plastic opening tools if necessary.
  2. Dell Inspiron 17-3721 CMOS Battery Replacement: passo 2, immagine 1 di 2 Dell Inspiron 17-3721 CMOS Battery Replacement: passo 2, immagine 2 di 2
    • Remove the CMOS battery with the plastic opening tools.
    • Be careful while prying it open, the battery holder can break if you use too much force.
    • Do not use metal tools when touching anything that can have an electric charge.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 932
