Salta al contenuto principale
Dell Inspiron 17 N7010 BIOS Battery Replacement
Cosa ti serve
  1. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove disc drive: passo 1, immagine 1 di 1
    • Remove the single Philips screw securing the disc drive.
    • Pull the disc drive out.
  2. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: passo 2, immagine 1 di 3 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: passo 2, immagine 2 di 3 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: passo 2, immagine 3 di 3
    • Remove the 22 M2.5x5 Philips screws securing the palmrest to the base.
    • Remove the seven remaining M2x2.5 screws securing the palmrest to the base.
    • Unscrew the two captive screws securing the RAM/HDD door to the base.
    • This must be done in order to access hidden screws under the hard drive.
    • Under the RAM/HDD door, unscrew the hard drive caddy. Remove the caddy.
    • Remove the three M2.5x5 screws from under where the hard drive was.
  3. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove keyboard: passo 3, immagine 1 di 1
    • Pop the four keyboard clips with a plastic spudger. As you do the first one, pry to get under the keyboard with your hand.
    • Remove the keyboard cable from the motherboard connector.
  4. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest: passo 4, immagine 1 di 2 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest: passo 4, immagine 2 di 2
    • Remove the palmrest cables from the motherboard connectors.
    • Remove the seven M2.5x5 screws securing the palmrest to the base.
    • Lift the palmrest.
  5. Dell Inspiron 17 N7010 BIOS Battery Replacement, Replace the cell: passo 5, immagine 1 di 1
    • Use a plastic spudger to get under the CR2032 cell and pry it out carefully.
Conclusione
Altre 14 persone hanno completato questa guida.
Joseph Sctbunio
Membro da: 09/23/17
7.332 Reputazione
42 Guide realizzate
7 Commenti
thanks for your help!!!
E P - Replica
I’m happy that my guide helped you!
Joseph Sctbunio -
Lot of screws, wouldn’t even tried this without these instruction.
Thank you.
d223e
Don Endress - Replica
Thanks for the instructions. Computer starts up great now.
jkleinjans - Replica
doresc sa comand pentru Dell Inspiron 17 N7010 BIOS Baterie. 1 bucata. cum se procedeaza?
Florentin Manolea - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 120
Tutti i Tempi: 17,960
