Salta al contenuto principale
Dell Inspiron 16-7620 RAM Replacement
Cosa ti serve
  1. Dell Inspiron 16-7620 RAM Replacement, RAM: passo 1, immagine 1 di 3 Dell Inspiron 16-7620 RAM Replacement, RAM: passo 1, immagine 2 di 3 Dell Inspiron 16-7620 RAM Replacement, RAM: passo 1, immagine 3 di 3
    • Using a Phillips #00 screwdriver, fully unscrew all seven 5 mm screws circled in red.
    • Using the same screwdriver, unscrew the two 5 mm screws circled in orange until the back of the laptop begins to pop off.
    • Keep in mind should not be fully removed; they are captive screws.
    • Starting near the hinges of the laptop, use a jimmy to work around the laptop, carefully prying the back off.
  2. Dell Inspiron 16-7620 RAM Replacement: passo 2, immagine 1 di 3 Dell Inspiron 16-7620 RAM Replacement: passo 2, immagine 2 di 3 Dell Inspiron 16-7620 RAM Replacement: passo 2, immagine 3 di 3
    • Lift up the black covers outlined in red to reveal the RAM module(s).
    • Gently push the two metal arms outwards to release the RAM module.
    • The RAM should pop out of its socket when you release the second tab.
  3. Dell Inspiron 16-7620 RAM Replacement: passo 3, immagine 1 di 2 Dell Inspiron 16-7620 RAM Replacement: passo 3, immagine 2 di 2
    • Remove the RAM by sliding outwards.
Conclusione
Lucian Chauvin
Membro da: 06/28/23
97 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 30
Tutti i Tempi: 255
