Salta al contenuto principale
Dell Inspiron 16-7610 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 16-7610 Battery Replacement, Back Case: passo 1, immagine 1 di 2 Dell Inspiron 16-7610 Battery Replacement, Back Case: passo 1, immagine 2 di 2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
    • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
  2. Dell Inspiron 16-7610 Battery Replacement: passo 2, immagine 1 di 1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 Battery Replacement, Battery: passo 3, immagine 1 di 3 Dell Inspiron 16-7610 Battery Replacement, Battery: passo 3, immagine 2 di 3 Dell Inspiron 16-7610 Battery Replacement, Battery: passo 3, immagine 3 di 3
    • Use a Phillips #00 to remove the five screws securing the battery to the laptop.
    • Pull the bundled cable away from the connector in the same direction as the wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Use both hands to life the battery up and remove it from the laptop.
Conclusione
Michael Torres
Membro da: 02/02/23
145 Reputazione
2 Guide realizzate
Gateway, Team 1-3, Pee Spring 2023 Membro di Gateway, Team 1-3, Pee Spring 2023
GCC-PEE-S23S1G3
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 77
Tutti i Tempi: 999
