Salta al contenuto principale
Dell Inspiron 16 7610 Back Case Replacement
Cosa ti serve
  1. Dell Inspiron 16 7610 Back Case Replacement, Back Case: passo 1, immagine 1 di 2 Dell Inspiron 16 7610 Back Case Replacement, Back Case: passo 1, immagine 2 di 2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
    • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
  2. Dell Inspiron 16 7610 Back Case Replacement: passo 2, immagine 1 di 1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
Conclusione
Jerson Gomez
Membro da: 02/02/23
877 Reputazione
3 Guide realizzate
Gateway, Team 1-3, Pee Spring 2023 Membro di Gateway, Team 1-3, Pee Spring 2023
GCC-PEE-S23S1G3
4 Membri
6 Guide realizzate
Un commento
Followed instructions. No clips broken but still cannot close the back cover. There’s a small gab in between the mouse and the cover when I close it.
Enos Nii Armah - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 48
Tutti i Tempi: 508
