Salta al contenuto principale
Dell Inspiron 15z 5523 Memory Module Replacement
Cosa ti serve
  1. Dell Inspiron 15z 5523 Memory Module Replacement, Loosen the Screw: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Close the display and turn the computer over.
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Dell Inspiron 15z 5523 Memory Module Replacement, Lifting the Module Cover: passo 2, immagine 1 di 1
    • Using your fingertips, lift the memory-module cover out of the slots on the computer base.
  3. Dell Inspiron 15z 5523 Memory Module Replacement, Popping up the Memory Module: passo 3, immagine 1 di 1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  4. Dell Inspiron 15z 5523 Memory Module Replacement, Sliding the Memory Module: passo 5, immagine 1 di 1
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
  5. Dell Inspiron 15z 5523 Memory Module Replacement, Slide the Tabs: passo 6, immagine 1 di 1
    • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
  6. Dell Inspiron 15z 5523 Memory Module Replacement, Tighten the Screw: passo 7, immagine 1 di 1
    • Tighten the captive screw that secures the memory-module cover to the computer base.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 184
