Salta al contenuto principale
Dell Inspiron 15z 1570 Memory Modules Replacement
Cosa ti serve
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
  1. Dell Inspiron 15z 1570 Memory Modules Replacement, Popping up the Memory Modules: passo 2, immagine 1 di 2 Dell Inspiron 15z 1570 Memory Modules Replacement, Popping up the Memory Modules: passo 2, immagine 2 di 2
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  2. Dell Inspiron 15z 1570 Memory Modules Replacement, Align the Notch: passo 3, immagine 1 di 2 Dell Inspiron 15z 1570 Memory Modules Replacement, Align the Notch: passo 3, immagine 2 di 2
    • Align the notch in the NEW memory module with the tab in the memory module connector.
  3. Dell Inspiron 15z 1570 Memory Modules Replacement, Sliding the Memory Module: passo 4, immagine 1 di 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.121 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 53
