Salta al contenuto principale
Dell Inspiron 15R N5110 Display Assembly Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Dell Inspiron 15R N5110 Display Assembly Replacement, Peel the Tape: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Peel the tape that secures the display cable to the system board.
  2. Dell Inspiron 15R N5110 Display Assembly Replacement, Disconnect the Display Cable: passo 2, immagine 1 di 1
    • Disconnect the display cable from the connectors on the system board.
  3. Dell Inspiron 15R N5110 Display Assembly Replacement, Disconnect the Cables: passo 3, immagine 1 di 1
    • Disconnect the wireless mini-card cables from the connectors on the wireless mini-card.
  4. Dell Inspiron 15R N5110 Display Assembly Replacement, Move the Power-Adapter Cable: passo 4, immagine 1 di 1
    • Move aside the power adapter-port cable from the screws.
  5. Dell Inspiron 15R N5110 Display Assembly Replacement, Remove the Screws: passo 5, immagine 1 di 1
    • Remove the screws that secure the display assembly to the computer base.
  6. Dell Inspiron 15R N5110 Display Assembly Replacement, Lifting the Display Assembly: passo 6, immagine 1 di 1
    • Lift the display assembly off the computer base.
  7. Dell Inspiron 15R N5110 Display Assembly Replacement, Placing the Display Assembly: passo 7, immagine 1 di 1
    • Place the NEW display assembly on the computer base and align the screw holes on the display assembly with the screw holes on the computer base.
  8. Dell Inspiron 15R N5110 Display Assembly Replacement, Replace the Screws: passo 8, immagine 1 di 1
    • Replace the screws that secure the display assembly to the computer base.
  9. Dell Inspiron 15R N5110 Display Assembly Replacement, Connecting the Cables: passo 9, immagine 1 di 1
    • Connect the wireless mini-card cables to the connectors on the wireless mini-card.
  10. Dell Inspiron 15R N5110 Display Assembly Replacement, Connect the Display Cable: passo 10, immagine 1 di 1
    • Connect the display cable to the connector on the system board.
  11. Dell Inspiron 15R N5110 Display Assembly Replacement, Adhere the Tape: passo 11, immagine 1 di 1
    • Adhere the tape that secures the display cable to the system board.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.091 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 166
