Salta al contenuto principale
Dell Inspiron 15R 5537 Motherboard Replacement
Cosa ti serve
  1. Dell Inspiron 15R 5537 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Before working inside your computer, read the safety information that shipped with your computer.
    • Close the display and turn over the computer to see the battery locking tabs.
  2. Dell Inspiron 15R 5537 Motherboard Replacement: passo 2, immagine 1 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 2, immagine 2 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 2, immagine 3 di 3
    • Pull both of the locking tabs outwards until they both click to release the battery.
    • Pull the battery out by lifting it from the top and sliding it forward.
  3. Dell Inspiron 15R 5537 Motherboard Replacement, Keyboard: passo 3, immagine 1 di 3 Dell Inspiron 15R 5537 Motherboard Replacement, Keyboard: passo 3, immagine 2 di 3 Dell Inspiron 15R 5537 Motherboard Replacement, Keyboard: passo 3, immagine 3 di 3
    • Turn the laptop over so that the keyboard is facing up.
    • Use an opening tool to pry the keyboard from the base of the laptop.
    • Once the top of the keyboard is released, slide the keyboard upwards.
    • Be sure not to pull the keyboard straight up; this could damage the keyboard ribbon cable.
  4. Dell Inspiron 15R 5537 Motherboard Replacement: passo 4, immagine 1 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 4, immagine 2 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 4, immagine 3 di 3
    • Use an opening tool to remove the keyboard ribbon from the latch by lifting the tab on top.
    • Once lifted, disconnect the ribbon and replace with a new keyboard.
  5. Dell Inspiron 15R 5537 Motherboard Replacement, Wi-Fi Module: passo 5, immagine 1 di 1
    • Once the keyboard is removed, the Wi-Fi module will be accessible.
  6. Dell Inspiron 15R 5537 Motherboard Replacement: passo 6, immagine 1 di 2 Dell Inspiron 15R 5537 Motherboard Replacement: passo 6, immagine 2 di 2
    • Use the opening tool to lift both antenna cables upward from the Wi-Fi module.
  7. Dell Inspiron 15R 5537 Motherboard Replacement: passo 7, immagine 1 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 7, immagine 2 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 7, immagine 3 di 3
    • Remove the 3mm Phillips #000 screw securing the Wi-Fi module.
    • Lift the Wi-Fi module up and out of the laptop.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  8. Dell Inspiron 15R 5537 Motherboard Replacement, Remove the Screws: passo 9, immagine 1 di 1
    • Remove the screws that secure the hard-drive assembly to the computer base.
  9. Dell Inspiron 15R 5537 Motherboard Replacement, Sliding the Hard Drive Assembly: passo 10, immagine 1 di 1
    • Slide the hard-drive assembly forward to disconnect the hard-drive assembly from the system board.
  10. Dell Inspiron 15R 5537 Motherboard Replacement, Lifting the Hard Drive Assembly: passo 11, immagine 1 di 1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  11. Dell Inspiron 15R 5537 Motherboard Replacement, Remove the Screws: passo 12, immagine 1 di 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  12. Dell Inspiron 15R 5537 Motherboard Replacement, Lifting the Hard-Drive Bracket: passo 13, immagine 1 di 1
    • Lift the hard-drive bracket off the hard drive.
  13. Dell Inspiron 15R 5537 Motherboard Replacement, Align the Screw Holes: passo 14, immagine 1 di 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  14. Dell Inspiron 15R 5537 Motherboard Replacement, Replace the Screws: passo 15, immagine 1 di 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  15. Dell Inspiron 15R 5537 Motherboard Replacement, Placing the Hard Drive Assembly: passo 16, immagine 1 di 1
    • Slide and place the hard-drive assembly in the hard-drive bay.
  16. Dell Inspiron 15R 5537 Motherboard Replacement, Sliding the Hard-Drive Assembly: passo 17, immagine 1 di 1
    • Slide the hard-drive assembly backward to connect the hard-drive assembly to the system board.
  17. Dell Inspiron 15R 5537 Motherboard Replacement, Replace the Screws: passo 18, immagine 1 di 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  18. Dell Inspiron 15R 5537 Motherboard Replacement, Palm Rest: passo 19, immagine 1 di 1
    • Remove thirteen 5mm Phillips #000 screws from the back cover of the laptop.
  19. Dell Inspiron 15R 5537 Motherboard Replacement: passo 20, immagine 1 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 20, immagine 2 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 20, immagine 3 di 3
    • Use the opening tool to unplug the palm rest cables and slide the cables out.
  20. Dell Inspiron 15R 5537 Motherboard Replacement: passo 21, immagine 1 di 1
    • Remove seven 5mm Phillips #000 screws from the midframe.
  21. Dell Inspiron 15R 5537 Motherboard Replacement: passo 22, immagine 1 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 22, immagine 2 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 22, immagine 3 di 3
    • Use the opening tool to lift the edges of the palm rest. Once all of the sides are lifted, pull the palm rest off.
  22. Dell Inspiron 15R 5537 Motherboard Replacement, Display Assembly: passo 23, immagine 1 di 2 Dell Inspiron 15R 5537 Motherboard Replacement, Display Assembly: passo 23, immagine 2 di 2
    • Unplug the DC jack to the right of the fan.
  23. Dell Inspiron 15R 5537 Motherboard Replacement: passo 24, immagine 1 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 24, immagine 2 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 24, immagine 3 di 3
    • Unplug the display cable below the fan by pulling the cable straight back.
  24. Dell Inspiron 15R 5537 Motherboard Replacement: passo 25, immagine 1 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 25, immagine 2 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 25, immagine 3 di 3
    • Unplug the display cable located near the right display hinge by lifting the tape and pulling back.
  25. Dell Inspiron 15R 5537 Motherboard Replacement: passo 26, immagine 1 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 26, immagine 2 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 26, immagine 3 di 3
    • Remove the two 5mm Phillips #000 screws from the left and right hinges.
  26. Dell Inspiron 15R 5537 Motherboard Replacement: passo 27, immagine 1 di 2 Dell Inspiron 15R 5537 Motherboard Replacement: passo 27, immagine 2 di 2
    • Remove the display assembly by lifting the display from the hinges.
    • It is important to ensure the display cables are fully disconnected before removing the assembly.
  27. Dell Inspiron 15R 5537 Motherboard Replacement, DC Jack: passo 28, immagine 1 di 3 Dell Inspiron 15R 5537 Motherboard Replacement, DC Jack: passo 28, immagine 2 di 3 Dell Inspiron 15R 5537 Motherboard Replacement, DC Jack: passo 28, immagine 3 di 3
    • Remove the DC jack once the display is removed by pulling the cable assembly upwards.
  28. Dell Inspiron 15R 5537 Motherboard Replacement, Motherboard: passo 29, immagine 1 di 3 Dell Inspiron 15R 5537 Motherboard Replacement, Motherboard: passo 29, immagine 2 di 3 Dell Inspiron 15R 5537 Motherboard Replacement, Motherboard: passo 29, immagine 3 di 3
    • Unplug the speaker cable.
  29. Dell Inspiron 15R 5537 Motherboard Replacement: passo 30, immagine 1 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 30, immagine 2 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 30, immagine 3 di 3
    • Remove the cable running over the hard drive by using the opening tool to lift the tab and pull back.
  30. Dell Inspiron 15R 5537 Motherboard Replacement: passo 31, immagine 1 di 1
    • Remove the single 5mm Phillips #000 screw.
  31. Dell Inspiron 15R 5537 Motherboard Replacement: passo 32, immagine 1 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 32, immagine 2 di 3 Dell Inspiron 15R 5537 Motherboard Replacement: passo 32, immagine 3 di 3
    • Remove the motherboard by lifting straight up. Ensure the CD drive is disconnected from the motherboard.
Conclusione
5 Commenti
Do you have a photo from the back of this motherboard? Does it support M.2?
Daniel G. Candido - Replica
Hey Daniel,
My names Cody and I was apart of the team that created this guide. To answer your question, sadly we did not take any pictures of the back of the motherboard when we had it disassembled. As for the compatibility for an M.2 drive I did not see a port that would be compatible with it but our computer could have a different motherboard than yours does, which means there is always a possibility that yours does have a slot for one. The only way to know is to take off the bottom cover of your computer and you would be able to see an existing M.2 in your motherboard or an empty slot for one.
Thank you for leaving a comment, I hope this helped you out.
Sincerely,
Cody Charnisky
Cody Charnisky -
hi
need to ask about somethings i have laptop dell inspiron 15R 5537 ( I5 / Ram 4g / GPU amd ) and need to upgrade Processor and the GPU i know it’s hard to do so i wonder if i can change the motherboard with high Processor like I7 ????
thank you
ma7ame7oo - Replica
Hi ma7ame7oo,
I'm cody and helped in the original making of this guide. To answer your question what you're looking for is compatibility. What I mean by that is Dell only made (from my knowledge) two different motherboards for this computer that would be compatible for it. That would be the inspiron GPU and the AMD GPU. There is always a possibility of being creative enough to find a motherboard to fit the computer, but that task is a little out of the ball park for the average person. So to answer your question I don't believe it would be possible to find a new motherboard with an I7 that would fit this specific computer and just plug and play. I'm sorry I couldn't help more but I hoped I answer you're question.
Cody Charnisky -
Hello, my name is Nico and I was wondering if I can buy a OEM motherboard same make/model/year, however with the i7? I currently have the Inspiron 15r 5537 with the i5, and thought I might be able to buy the Inspiron 15r 5537 motherboard with the i7 and swap them out with intentions of upgrading the CPU and GPU that comes with the OEM i7 motherboard?? I’ve been looking for an answer on the internet however have yet to find a direct answer.
Nico Armz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 35
Tutti i Tempi: 2,592
