Salta al contenuto principale
Dell Inspiron 15R 5537 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 15R 5537 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Before working inside your computer, read the safety information that shipped with your computer.
    • Close the display and turn over the computer to see the battery locking tabs.
  2. Dell Inspiron 15R 5537 Keyboard Replacement: passo 2, immagine 1 di 3 Dell Inspiron 15R 5537 Keyboard Replacement: passo 2, immagine 2 di 3 Dell Inspiron 15R 5537 Keyboard Replacement: passo 2, immagine 3 di 3
    • Pull both of the locking tabs outwards until they both click to release the battery.
    • Pull the battery out by lifting it from the top and sliding it forward.
  3. Dell Inspiron 15R 5537 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 3 Dell Inspiron 15R 5537 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 3 Dell Inspiron 15R 5537 Keyboard Replacement, Keyboard: passo 3, immagine 3 di 3
    • Turn the laptop over so that the keyboard is facing up.
    • Use an opening tool to pry the keyboard from the base of the laptop.
    • Once the top of the keyboard is released, slide the keyboard upwards.
    • Be sure not to pull the keyboard straight up; this could damage the keyboard ribbon cable.
  4. Dell Inspiron 15R 5537 Keyboard Replacement: passo 4, immagine 1 di 3 Dell Inspiron 15R 5537 Keyboard Replacement: passo 4, immagine 2 di 3 Dell Inspiron 15R 5537 Keyboard Replacement: passo 4, immagine 3 di 3
    • Use an opening tool to remove the keyboard ribbon from the latch by lifting the tab on top.
    • Once lifted, disconnect the ribbon and replace with a new keyboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 23
Tutti i Tempi: 981
