Salta al contenuto principale
Dell Inspiron 15R 5537 DC Jack Replacement
Cosa ti serve
  1. Dell Inspiron 15R 5537 DC Jack Replacement, Battery: passo 1, immagine 1 di 1
    • Before working inside your computer, read the safety information that shipped with your computer.
    • Close the display and turn over the computer to see the battery locking tabs.
  2. Dell Inspiron 15R 5537 DC Jack Replacement: passo 2, immagine 1 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 2, immagine 2 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 2, immagine 3 di 3
    • Pull both of the locking tabs outwards until they both click to release the battery.
    • Pull the battery out by lifting it from the top and sliding it forward.
  3. Dell Inspiron 15R 5537 DC Jack Replacement, Keyboard: passo 3, immagine 1 di 3 Dell Inspiron 15R 5537 DC Jack Replacement, Keyboard: passo 3, immagine 2 di 3 Dell Inspiron 15R 5537 DC Jack Replacement, Keyboard: passo 3, immagine 3 di 3
    • Turn the laptop over so that the keyboard is facing up.
    • Use an opening tool to pry the keyboard from the base of the laptop.
    • Once the top of the keyboard is released, slide the keyboard upwards.
    • Be sure not to pull the keyboard straight up; this could damage the keyboard ribbon cable.
  4. Dell Inspiron 15R 5537 DC Jack Replacement: passo 4, immagine 1 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 4, immagine 2 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 4, immagine 3 di 3
    • Use an opening tool to remove the keyboard ribbon from the latch by lifting the tab on top.
    • Once lifted, disconnect the ribbon and replace with a new keyboard.
  5. Dell Inspiron 15R 5537 DC Jack Replacement, Wi-Fi Module: passo 5, immagine 1 di 1
    • Once the keyboard is removed, the Wi-Fi module will be accessible.
  6. Dell Inspiron 15R 5537 DC Jack Replacement: passo 6, immagine 1 di 2 Dell Inspiron 15R 5537 DC Jack Replacement: passo 6, immagine 2 di 2
    • Use the opening tool to lift both antenna cables upward from the Wi-Fi module.
  7. Dell Inspiron 15R 5537 DC Jack Replacement: passo 7, immagine 1 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 7, immagine 2 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 7, immagine 3 di 3
    • Remove the 3mm Phillips #000 screw securing the Wi-Fi module.
    • Lift the Wi-Fi module up and out of the laptop.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  8. Dell Inspiron 15R 5537 DC Jack Replacement, Remove the Screws: passo 9, immagine 1 di 1
    • Remove the screws that secure the hard-drive assembly to the computer base.
  9. Dell Inspiron 15R 5537 DC Jack Replacement, Sliding the Hard Drive Assembly: passo 10, immagine 1 di 1
    • Slide the hard-drive assembly forward to disconnect the hard-drive assembly from the system board.
  10. Dell Inspiron 15R 5537 DC Jack Replacement, Lifting the Hard Drive Assembly: passo 11, immagine 1 di 1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  11. Dell Inspiron 15R 5537 DC Jack Replacement, Remove the Screws: passo 12, immagine 1 di 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  12. Dell Inspiron 15R 5537 DC Jack Replacement, Lifting the Hard-Drive Bracket: passo 13, immagine 1 di 1
    • Lift the hard-drive bracket off the hard drive.
  13. Dell Inspiron 15R 5537 DC Jack Replacement, Align the Screw Holes: passo 14, immagine 1 di 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  14. Dell Inspiron 15R 5537 DC Jack Replacement, Replace the Screws: passo 15, immagine 1 di 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  15. Dell Inspiron 15R 5537 DC Jack Replacement, Placing the Hard Drive Assembly: passo 16, immagine 1 di 1
    • Slide and place the hard-drive assembly in the hard-drive bay.
  16. Dell Inspiron 15R 5537 DC Jack Replacement, Sliding the Hard-Drive Assembly: passo 17, immagine 1 di 1
    • Slide the hard-drive assembly backward to connect the hard-drive assembly to the system board.
  17. Dell Inspiron 15R 5537 DC Jack Replacement, Replace the Screws: passo 18, immagine 1 di 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  18. Dell Inspiron 15R 5537 DC Jack Replacement, Palm Rest: passo 19, immagine 1 di 1
    • Remove thirteen 5mm Phillips #000 screws from the back cover of the laptop.
  19. Dell Inspiron 15R 5537 DC Jack Replacement: passo 20, immagine 1 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 20, immagine 2 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 20, immagine 3 di 3
    • Use the opening tool to unplug the palm rest cables and slide the cables out.
  20. Dell Inspiron 15R 5537 DC Jack Replacement: passo 21, immagine 1 di 1
    • Remove seven 5mm Phillips #000 screws from the midframe.
  21. Dell Inspiron 15R 5537 DC Jack Replacement: passo 22, immagine 1 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 22, immagine 2 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 22, immagine 3 di 3
    • Use the opening tool to lift the edges of the palm rest. Once all of the sides are lifted, pull the palm rest off.
  22. Dell Inspiron 15R 5537 DC Jack Replacement, Display Assembly: passo 23, immagine 1 di 2 Dell Inspiron 15R 5537 DC Jack Replacement, Display Assembly: passo 23, immagine 2 di 2
    • Unplug the DC jack to the right of the fan.
  23. Dell Inspiron 15R 5537 DC Jack Replacement: passo 24, immagine 1 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 24, immagine 2 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 24, immagine 3 di 3
    • Unplug the display cable below the fan by pulling the cable straight back.
  24. Dell Inspiron 15R 5537 DC Jack Replacement: passo 25, immagine 1 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 25, immagine 2 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 25, immagine 3 di 3
    • Unplug the display cable located near the right display hinge by lifting the tape and pulling back.
  25. Dell Inspiron 15R 5537 DC Jack Replacement: passo 26, immagine 1 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 26, immagine 2 di 3 Dell Inspiron 15R 5537 DC Jack Replacement: passo 26, immagine 3 di 3
    • Remove the two 5mm Phillips #000 screws from the left and right hinges.
  26. Dell Inspiron 15R 5537 DC Jack Replacement: passo 27, immagine 1 di 2 Dell Inspiron 15R 5537 DC Jack Replacement: passo 27, immagine 2 di 2
    • Remove the display assembly by lifting the display from the hinges.
    • It is important to ensure the display cables are fully disconnected before removing the assembly.
  27. Dell Inspiron 15R 5537 DC Jack Replacement, DC Jack: passo 28, immagine 1 di 3 Dell Inspiron 15R 5537 DC Jack Replacement, DC Jack: passo 28, immagine 2 di 3 Dell Inspiron 15R 5537 DC Jack Replacement, DC Jack: passo 28, immagine 3 di 3
    • Remove the DC jack once the display is removed by pulling the cable assembly upwards.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 19
Tutti i Tempi: 875
