Introduzione
In this guide, we will be showing you how to remove and replace the Memory Module.
Cosa ti serve
Loosen the captive screw that secures the memory-module cover to the computer base.
Using your fingertips, lift the memory-module cover out of the slots on the computer base.
Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Remove the memory module from the memory-module connector.
Align the notch on the NEW memory module with the tab on the memory-module connector.
Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
Tighten the captive screw that secures the memory-module cover to the computer base.
