Salta al contenuto principale
Dell Inspiron 15R 5521 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 15R 5521 Display Assembly Replacement, Peeling the Tape: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Peel the tape that secures the display cable to the system board.
  2. Dell Inspiron 15R 5521 Display Assembly Replacement, Disconnecting the Display Cable: passo 2, immagine 1 di 1
    • Disconnect the display cable from the connectors on the system board.
  3. Dell Inspiron 15R 5521 Display Assembly Replacement, Disconnect the Cables: passo 3, immagine 1 di 1
    • Disconnect the wireless mini-card cables from the connectors on the wireless mini-card.
  4. Dell Inspiron 15R 5521 Display Assembly Replacement, Moving the Port Cable: passo 4, immagine 1 di 1
    • Move aside the power adapter-port cable from the screws.
  5. Dell Inspiron 15R 5521 Display Assembly Replacement, Remove the Screws: passo 5, immagine 1 di 1
    • Remove the screws that secure the display assembly to the computer base.
  6. Dell Inspiron 15R 5521 Display Assembly Replacement, Lift the Display Assembly: passo 6, immagine 1 di 1
    • Lift the display assembly off the computer base.
  7. Dell Inspiron 15R 5521 Display Assembly Replacement, Placing the Display Assembly: passo 7, immagine 1 di 1
    • Place the NEW display assembly on the computer base and align the screw holes on the display assembly with the screw holes on the computer base.
  8. Dell Inspiron 15R 5521 Display Assembly Replacement, Replace the Screws: passo 8, immagine 1 di 1
    • Replace the screws that secure the display assembly to the computer base.
  9. Dell Inspiron 15R 5521 Display Assembly Replacement, Connecting the Cables: passo 9, immagine 1 di 1
    • Connect the wireless mini-card cables to the connectors on the wireless mini-card.
  10. Dell Inspiron 15R 5521 Display Assembly Replacement, Connect the Display Cable: passo 10, immagine 1 di 1
    • Connect the display cable to the connector on the system board.
  11. Dell Inspiron 15R 5521 Display Assembly Replacement, Adhering the Tape: passo 11, immagine 1 di 1
    • Adhere the tape that secures the display cable to the system board.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 658
