Salta al contenuto principale
Dell Inspiron 15R 5520 Memory Module Replacement
Cosa ti serve
  1. Dell Inspiron 15R 5520 Memory Module Replacement, Popping up the Memory Module: passo 1, immagine 1 di 2 Dell Inspiron 15R 5520 Memory Module Replacement, Popping up the Memory Module: passo 1, immagine 2 di 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  2. Dell Inspiron 15R 5520 Memory Module Replacement, Remove the Memory Module: passo 2, immagine 1 di 1
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron 15R 5520 Memory Module Replacement, Align the Notch: passo 3, immagine 1 di 2 Dell Inspiron 15R 5520 Memory Module Replacement, Align the Notch: passo 3, immagine 2 di 2
    • Align the notch on the memory module with the tab on the memory-module connector.
  4. Dell Inspiron 15R 5520 Memory Module Replacement, Sliding the Memory Module: passo 4, immagine 1 di 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.131 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.986 Guide realizzate
2 Commenti
I took apart my dell inspiron 15r 5520 to replace the Wi-Fi card & now the touchpad & buttons will not work. What might have I done wrong?
jdoerr9619 - Replica
الكمبيوتر يصدر صفاره عدد اربعه ولا يقلع
النظام
نبيل العامري - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 318
