Salta al contenuto principale
Dell Inspiron 1564 RAM Replacement
Cosa ti serve
  1. Dell Inspiron 1564 RAM Replacement, RAM: passo 1, immagine 1 di 2 Dell Inspiron 1564 RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Locate the battery latch on the bottom of the computer and slide it to the right.
    • While holding the battery latch, pull the battery away from the device.
  2. Dell Inspiron 1564 RAM Replacement: passo 2, immagine 1 di 1
    • With the Phillips #0 screwdriver, loosen the three screws from the cover behind the battery latch.
  3. Dell Inspiron 1564 RAM Replacement: passo 3, immagine 1 di 3 Dell Inspiron 1564 RAM Replacement: passo 3, immagine 2 di 3 Dell Inspiron 1564 RAM Replacement: passo 3, immagine 3 di 3
    • Locate the RAM on the bottom of the computer.
    • Remove the RAM by gently pulling back the small clips along the side of the RAM, and lifting the RAM upwards so the RAM is now angled.
    • Pull the RAM away from the device.
    • Repeat the actions above for the second stick of RAM.
    • When reinstalling the RAM, put it back in at an angle in the socket, and make sure the RAM is audiblely clicked into place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 946
