Salta al contenuto principale
Dell Inspiron 1564 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 1564 Hard Drive Replacement, Remove Battery: passo 1, immagine 1 di 2 Dell Inspiron 1564 Hard Drive Replacement, Remove Battery: passo 1, immagine 2 di 2
    • Locate battery latch on bottom of computer and slide to right.
    • While holding battery latch, pull the battery away from device and the battery will come free.
  2. Dell Inspiron 1564 Hard Drive Replacement, Remove Bottom Cover Screws: passo 2, immagine 1 di 1
    • With a J0 screwdriver bit, loosen all screws from the backing above the battery latch and remove the covering.
  3. Dell Inspiron 1564 Hard Drive Replacement, Hard Drive Removal: passo 3, immagine 1 di 2 Dell Inspiron 1564 Hard Drive Replacement, Hard Drive Removal: passo 3, immagine 2 di 2
    • Locate the three 4mm screws securing the hard drive and unscrew them with a J0 screwdriver.
    • Slide the hard drive to the left to unplug the SATA data and SATA power cables, then gently pry upwards and pull the drive away from device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,955
