Introduzione
In this guide, we will be showing you how to remove and replace the Hard Drive.
Parti
Nessuna parte richiesta.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard drive assembly to the computer base.
  2. Slide the hard drive assembly out of the hard drive compartment.
    • Slide the hard drive assembly out of the hard drive compartment.
  3. Remove the two screws that secure the hard drive bezel to the hard drive.
    • Remove the two screws that secure the hard drive bezel to the hard drive.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Lift the hard drive bezel off the hard drive. Lift the hard drive bezel off the hard drive.
    • Lift the hard drive bezel off the hard drive.
  6. Align the screw holes on the hard drive bezel with the holes on the NEW hard drive.
    • Align the screw holes on the hard drive bezel with the holes on the NEW hard drive.
  7. Replace the two screws that secure the hard drive bezel to the hard drive.
    • Replace the two screws that secure the hard drive bezel to the hard drive.
  8. Slide the hard drive assembly into the hard drive compartment until it is fully seated.
    • Slide the hard drive assembly into the hard drive compartment until it is fully seated.
  9. Replace the two screws that secure the hard drive assembly to the computer base.
    • Replace the two screws that secure the hard drive assembly to the computer base.
Linea Traguardo
Terrence15
Membro da: 18/12/2017
70.653 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 28
