Introduzione
In this guide, we will be showing you how to remove and replace the Display Assembly.
Parti
Nessuna parte richiesta.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Make note of the Mini-Card antenna cables routing and remove the cables from the routing guides.
  2. Remove the two screws from the computer base.
    • Remove the two screws from the computer base.
  3. Make note of the Mini-Card antenna cable routing and carefully dislodge the antenna cables from the cable routing slot on the computer. Pull the cables away, so that they are clear of the palm rest.
    • Make note of the Mini-Card antenna cable routing and carefully dislodge the antenna cables from the cable routing slot on the computer. Pull the cables away, so that they are clear of the palm rest.
  4. Disconnect the display cable and camera cable from the respective system board connectors and remove them from their routing guides.
    • Disconnect the display cable and camera cable from the respective system board connectors and remove them from their routing guides.
  5. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  6. Remove the four screws that secure the display assembly to the computer base.
    • Remove the four screws that secure the display assembly to the computer base.
  7. Lift and remove the display assembly from the computer base.
    • Lift and remove the display assembly from the computer base.
  8. Place the display assembly in position and replace the four screws that secure the display assembly to the computer base.
    • Place the display assembly in position and replace the four screws that secure the display assembly to the computer base.
  9. Route the display cable and camera cable into their routing guides and connect the cables to the respective system board connectors.
    • Route the display cable and camera cable into their routing guides and connect the cables to the respective system board connectors.
  10. Route the Mini-Card antenna cables, and guide the cables to the bottom of the computer through the cable routing slot.
    • Route the Mini-Card antenna cables, and guide the cables to the bottom of the computer through the cable routing slot.
  11. Replace the two screws at the bottom of the computer.
    • Replace the two screws at the bottom of the computer.
Linea Traguardo
Terrence15
Membro da: 18/12/2017
70.653 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 19
