Salta al contenuto principale
Dell Inspiron 1545 RAM Replacement
Cosa ti serve
  1. Dell Inspiron 1545 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 RAM Replacement: passo 2, immagine 1 di 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 RAM Replacement: passo 3, immagine 1 di 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 RAM Replacement, Base Cover: passo 4, immagine 1 di 1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 RAM Replacement: passo 5, immagine 1 di 2 Dell Inspiron 1545 RAM Replacement: passo 5, immagine 2 di 2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 RAM Replacement, RAM: passo 6, immagine 1 di 1
    • Spread apart the securing clips on each end of the memory stick until the memory stick pops up.
    • Remove the memory stick from the laptop.
    • Repeat these steps to remove the second memory stick.
Conclusione
Altre 9 persone hanno completato questa guida.
Nathan Lemay
Membro da: 04/16/14
3.052 Reputazione
15 Guide realizzate
Cal Poly, Team 9-14, Regan Spring 2014 Membro di Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,873
