Salta al contenuto principale
Dell Inspiron 1545 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 1545 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Keyboard Replacement: passo 2, immagine 1 di 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Keyboard Replacement: passo 3, immagine 1 di 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Keyboard Replacement, Base Cover: passo 4, immagine 1 di 1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 Keyboard Replacement: passo 5, immagine 1 di 2 Dell Inspiron 1545 Keyboard Replacement: passo 5, immagine 2 di 2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 Keyboard Replacement, Center Control Cover: passo 6, immagine 1 di 1
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  7. Dell Inspiron 1545 Keyboard Replacement: passo 7, immagine 1 di 1
    • Flip the laptop over to the front and open the display as far as possible.
  8. Dell Inspiron 1545 Keyboard Replacement: passo 8, immagine 1 di 3 Dell Inspiron 1545 Keyboard Replacement: passo 8, immagine 2 di 3 Dell Inspiron 1545 Keyboard Replacement: passo 8, immagine 3 di 3
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
  9. Dell Inspiron 1545 Keyboard Replacement, Keyboard: passo 9, immagine 1 di 1
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  10. Dell Inspiron 1545 Keyboard Replacement: passo 10, immagine 1 di 1
    • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
    • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
  11. Dell Inspiron 1545 Keyboard Replacement: passo 11, immagine 1 di 1
    • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
    The connector latch is the black piece.
    Maurice Volaski - Replica
    Good tip! As shown. flips up and toward user
    Tom Borden - Replica
  12. Dell Inspiron 1545 Keyboard Replacement: passo 12, immagine 1 di 1
    • Lift the keyboard up and away from the laptop.
Conclusione
Altre 15 persone hanno completato questa guida.
Nathan Lemay
Membro da: 04/16/14
3.052 Reputazione
15 Guide realizzate
Cal Poly, Team 9-14, Regan Spring 2014 Membro di Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Membri
15 Guide realizzate
2 Commenti
Step 4 and 5 are not needed.
James Thrun - Replica
Steps 4 and 5 are unnecessary for removing the keyboard. Other than that, well done.
lee - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 6,843
