Salta al contenuto principale
Dell Inspiron 1545 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 1545 Hard Drive Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • CAUTION: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • Remove the two screws securing the hard drive assembly to the computer base.
  2. Dell Inspiron 1545 Hard Drive Replacement, Sliding the Hard Drive Assembly: passo 2, immagine 1 di 1
    • Slide the hard drive assembly out of the bay.
  3. Dell Inspiron 1545 Hard Drive Replacement, Remove the Screws: passo 3, immagine 1 di 1
    • Remove the two screws (one from either side) securing the hard drive cage and bezel to the hard drive.
  4. Dell Inspiron 1545 Hard Drive Replacement, Remove the Hard Drive Bezel: passo 4, immagine 1 di 1
    • Remove the hard drive bezel.
  5. Dell Inspiron 1545 Hard Drive Replacement, Lifting the Hard Drive: passo 5, immagine 1 di 2 Dell Inspiron 1545 Hard Drive Replacement, Lifting the Hard Drive: passo 5, immagine 2 di 2
    • Lift the hard drive cage off the hard drive.
  6. Dell Inspiron 1545 Hard Drive Replacement, Replace the Hard Drive Cage: passo 6, immagine 1 di 2 Dell Inspiron 1545 Hard Drive Replacement, Replace the Hard Drive Cage: passo 6, immagine 2 di 2
    • Replace the hard drive cage and the hard drive bezel.
  7. Dell Inspiron 1545 Hard Drive Replacement, Replace the Screws: passo 7, immagine 1 di 1
    • Replace the two screws (one on either side) that secure the hard drive cage and bezel to the NEW hard drive.
  8. Dell Inspiron 1545 Hard Drive Replacement, Sliding the Hard Drive Assembly: passo 8, immagine 1 di 1
    • Slide the hard drive assembly into the bay.
  9. Dell Inspiron 1545 Hard Drive Replacement, Replace the Screws: passo 9, immagine 1 di 1
    • Replace the two screws that secure the hard drive assembly to the computer base.
    • NOTICE: Before turning on the computer, replace all screws and ensure that no stray screws remain inside the computer. Failure to do so may result in damage to the computer.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Terrence15
Membro da: 12/18/17
79.522 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
43 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 52
Tutti i Tempi: 5,900
