Salta al contenuto principale
Dell Inspiron 1526 Screen Replacement
Cosa ti serve
  1. Dell Inspiron 1526 Screen Replacement, Battery: passo 1, immagine 1 di 3 Dell Inspiron 1526 Screen Replacement, Battery: passo 1, immagine 2 di 3 Dell Inspiron 1526 Screen Replacement, Battery: passo 1, immagine 3 di 3
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Screen Replacement, Keyboard: passo 2, immagine 1 di 1
    • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
  3. Dell Inspiron 1526 Screen Replacement: passo 3, immagine 1 di 1
    • Flip the laptop over.
    • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
  4. Dell Inspiron 1526 Screen Replacement: passo 4, immagine 1 di 1
    • Carefully lift the control cover up and forward to reveal a single ribbon cable.
  5. Dell Inspiron 1526 Screen Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
  6. Dell Inspiron 1526 Screen Replacement: passo 6, immagine 1 di 2 Dell Inspiron 1526 Screen Replacement: passo 6, immagine 2 di 2
    • Remove the control cover.
  7. Dell Inspiron 1526 Screen Replacement: passo 7, immagine 1 di 1
    • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
  8. Dell Inspiron 1526 Screen Replacement: passo 8, immagine 1 di 1
    • Lift the keyboard gently from the top, but do not remove completely.
    • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
  9. Dell Inspiron 1526 Screen Replacement: passo 9, immagine 1 di 2 Dell Inspiron 1526 Screen Replacement: passo 9, immagine 2 di 2
    • Remove the keyboard.
  10. Dell Inspiron 1526 Screen Replacement, Screen: passo 10, immagine 1 di 2 Dell Inspiron 1526 Screen Replacement, Screen: passo 10, immagine 2 di 2
    • Remove the six plastic pads around the bezel using an iFixit opening pick.
    • Remove the six 3mm Phillips #0 screws under each pad.
  11. Dell Inspiron 1526 Screen Replacement: passo 11, immagine 1 di 3 Dell Inspiron 1526 Screen Replacement: passo 11, immagine 2 di 3 Dell Inspiron 1526 Screen Replacement: passo 11, immagine 3 di 3
    • Open the computer so that it rests flat on the table.
    • Separate the bezel from the black plastic frame using a spudger.
    • There are a dozen snaps around the perimeter of the bezel and there are two between the pivot joints of the laptop.
  12. Dell Inspiron 1526 Screen Replacement: passo 12, immagine 1 di 2 Dell Inspiron 1526 Screen Replacement: passo 12, immagine 2 di 2
    • Remove the two 3mm Phillips #1 screws at the bottom of the display panel.
    • Lift the display slightly from the top, then pull outwards.
    • Flip the display panel around to the back.
    • Disconnect the connector and remove the ribbon cable.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 198
