Salta al contenuto principale
Dell Inspiron 1526 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 1526 Hard Drive Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • Follow the procedures in Before You Begin.
    • Turn the computer over and remove the two hard drive screws.
  2. Dell Inspiron 1526 Hard Drive Replacement, Sliding the Hard Drive: passo 2, immagine 1 di 1
    • Slide the hard drive out of the computer.
  3. Dell Inspiron 1526 Hard Drive Replacement, Remove the Screws: passo 3, immagine 1 di 2 Dell Inspiron 1526 Hard Drive Replacement, Remove the Screws: passo 3, immagine 2 di 2
    • Remove the two screws (one from each side of the hard drive cover), then pull to separate the cover from the hard drive.
  4. Dell Inspiron 1526 Hard Drive Replacement, Replace the Hard Drive Cover: passo 4, immagine 1 di 2 Dell Inspiron 1526 Hard Drive Replacement, Replace the Hard Drive Cover: passo 4, immagine 2 di 2
    • Replace the hard drive cover and tighten the two screws to secure the cover to the NEW hard drive.
  5. Dell Inspiron 1526 Hard Drive Replacement, Sliding the Hard Drive: passo 5, immagine 1 di 1
    • NOTICE: Use firm and even pressure to slide the hard drive into place. Excessive force may result in damage to the connector.
    • Slide the hard drive into the hard drive bay until the drive is fully seated.
  6. Dell Inspiron 1526 Hard Drive Replacement, Replace the Screws: passo 6, immagine 1 di 1
    • Replace the two screws to secure the hard drive.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.309 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.984 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 188
