Salta al contenuto principale
Dell Inspiron 1525 Wireless Mini-Card Replacement
Cosa ti serve
  1. Dell Inspiron 1525 Wireless Mini-Card Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Wireless Mini-Card Replacement: passo 2, immagine 1 di 2 Dell Inspiron 1525 Wireless Mini-Card Replacement: passo 2, immagine 2 di 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Wireless Mini-Card Replacement, Bottom Cover: passo 3, immagine 1 di 2 Dell Inspiron 1525 Wireless Mini-Card Replacement, Bottom Cover: passo 3, immagine 2 di 2
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 Wireless Mini-Card Replacement, Wireless Mini-Card: passo 4, immagine 1 di 2 Dell Inspiron 1525 Wireless Mini-Card Replacement, Wireless Mini-Card: passo 4, immagine 2 di 2
    • Use the flat end of a spudger to gently pry the black and white antenna connectors off the Wireless Mini-Card.
  5. Dell Inspiron 1525 Wireless Mini-Card Replacement: passo 5, immagine 1 di 2 Dell Inspiron 1525 Wireless Mini-Card Replacement: passo 5, immagine 2 di 2
    • Remove the 3.70 mm Phillips #1 screw securing the card to the laptop.
    • The card will tilt up when you remove the screw.
    • Slide the card straight out.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 8,863
