Salta al contenuto principale
Dell Inspiron 1525 Hard Drive Tray Replacement
Cosa ti serve
  1. Dell Inspiron 1525 Hard Drive Tray Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Hard Drive Tray Replacement: passo 2, immagine 1 di 2 Dell Inspiron 1525 Hard Drive Tray Replacement: passo 2, immagine 2 di 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive: passo 3, immagine 1 di 3 Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive: passo 3, immagine 2 di 3 Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive: passo 3, immagine 3 di 3
    • Remove the two 3.60 mm #1 Phillips screws securing the hard drive and hard drive tray.
    • Slide the hard drive and hard drive tray out of the laptop.
  4. Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive Tray: passo 4, immagine 1 di 2 Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive Tray: passo 4, immagine 2 di 2
    • Remove the two 3.55 mm Phillips #1 screws securing the hard drive to the hard drive tray.
    • There is 1 screw on each side of the tray.
    • Remove the hard drive from the tray.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,365
