Salta al contenuto principale
Dell Inspiron 1525 Central Control Cover Replacement
Cosa ti serve
  1. Dell Inspiron 1525 Central Control Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Central Control Cover Replacement: passo 2, immagine 1 di 2 Dell Inspiron 1525 Central Control Cover Replacement: passo 2, immagine 2 di 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Central Control Cover Replacement, Central Control Cover: passo 3, immagine 1 di 1
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Central Control Cover Replacement: passo 4, immagine 1 di 3 Dell Inspiron 1525 Central Control Cover Replacement: passo 4, immagine 2 di 3 Dell Inspiron 1525 Central Control Cover Replacement: passo 4, immagine 3 di 3
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Central Control Cover Replacement: passo 5, immagine 1 di 3 Dell Inspiron 1525 Central Control Cover Replacement: passo 5, immagine 2 di 3 Dell Inspiron 1525 Central Control Cover Replacement: passo 5, immagine 3 di 3
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
Conclusione
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,739
