Salta al contenuto principale
Dell Inspiron 1521 Memory Modules Replacement
Cosa ti serve
  1. Dell Inspiron 1521 Memory Modules Replacement, Lifting the Module Cover: passo 1, immagine 1 di 1
    • Follow the procedures in Before You Begin.
    • Lift the memory module cover but do not remove it.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
  2. Dell Inspiron 1521 Memory Modules Replacement, Popping up the Memory Module: passo 2, immagine 1 di 1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  3. Dell Inspiron 1521 Memory Modules Replacement, Remove the DIMM A Memory Module: passo 3, immagine 1 di 1
    • Remove the module from the connector.
  4. Dell Inspiron 1521 Memory Modules Replacement, DIMM B Memory Module: passo 4, immagine 1 di 1
    • Turn the computer over.
    • Loosen the captive screw on the memory module cover, then remove the cover and set it aside.
  5. Dell Inspiron 1521 Memory Modules Replacement, Popping up the Memory Module: passo 5, immagine 1 di 2 Dell Inspiron 1521 Memory Modules Replacement, Popping up the Memory Module: passo 5, immagine 2 di 2
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  6. Dell Inspiron 1521 Memory Modules Replacement, Remove the Memory Module: passo 6, immagine 1 di 1
    • Remove the memory module from the connector.
  7. Dell Inspiron 1521 Memory Modules Replacement, Replacing DIMM A Memory Module: passo 7, immagine 1 di 2 Dell Inspiron 1521 Memory Modules Replacement, Replacing DIMM A Memory Module: passo 7, immagine 2 di 2
    • Align the notch in the memory module edge connector with the tab in the connector slot.
  8. Dell Inspiron 1521 Memory Modules Replacement, Sliding the Memory Module: passo 8, immagine 1 di 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot. No error message indicates this failure.
  9. Dell Inspiron 1521 Memory Modules Replacement, Replace the Memory Module Cover: passo 9, immagine 1 di 1
    • Replace the memory module cover.
  10. Dell Inspiron 1521 Memory Modules Replacement, Loosen the Screw: passo 10, immagine 1 di 1
  11. Dell Inspiron 1521 Memory Modules Replacement, Align the Notch: passo 11, immagine 1 di 2 Dell Inspiron 1521 Memory Modules Replacement, Align the Notch: passo 11, immagine 2 di 2
    • Align the notch in the module edge connector with the tab in the connector slot.
  12. Dell Inspiron 1521 Memory Modules Replacement, Sliding the Module: passo 12, immagine 1 di 1
    • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    • NOTICE: If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
  13. Dell Inspiron 1521 Memory Modules Replacement, Replace the Module Cover: passo 13, immagine 1 di 2 Dell Inspiron 1521 Memory Modules Replacement, Replace the Module Cover: passo 13, immagine 2 di 2
    • Replace the memory module cover and tighten the screw.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.091 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 187
