Salta al contenuto principale
Dell Inspiron 1521 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 1521 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 Keyboard Replacement: passo 2, immagine 1 di 3 Dell Inspiron 1521 Keyboard Replacement: passo 2, immagine 2 di 3 Dell Inspiron 1521 Keyboard Replacement: passo 2, immagine 3 di 3
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 3 Dell Inspiron 1521 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 3 Dell Inspiron 1521 Keyboard Replacement, Keyboard: passo 3, immagine 3 di 3
    • Find the two small indentations of the sides of the panel covering the power button.
    • Pry up both sides of the panel by sticking the plastic opener tool in each indentation and prying up.
  4. Dell Inspiron 1521 Keyboard Replacement: passo 4, immagine 1 di 1
    • Now that the panel is loose simply pull the panel off with your hand.
  5. Dell Inspiron 1521 Keyboard Replacement: passo 5, immagine 1 di 3 Dell Inspiron 1521 Keyboard Replacement: passo 5, immagine 2 di 3 Dell Inspiron 1521 Keyboard Replacement: passo 5, immagine 3 di 3
    • Locate the two 5 mm Phillips #1 screws holding down the keyboard that were underneath the panel.
    • Remove these screws with a Phillips #1 screwdriver.
    • With the screws removed pull the keyboard up with your hand.
  6. Dell Inspiron 1521 Keyboard Replacement: passo 6, immagine 1 di 3 Dell Inspiron 1521 Keyboard Replacement: passo 6, immagine 2 di 3 Dell Inspiron 1521 Keyboard Replacement: passo 6, immagine 3 di 3
    • Locate the connector that links the keyboard to the laptop.
    • Gently pull the connector toward the screen of the laptop with your figers to disconnect it.
Conclusione
Cal Poly, Team 15-47, Forte Fall 2012 Membro di Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,066
