Salta al contenuto principale
Dell Inspiron 1521 DVD Drive Replacement
Cosa ti serve
  1. Dell Inspiron 1521 DVD Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 DVD Drive Replacement: passo 2, immagine 1 di 3 Dell Inspiron 1521 DVD Drive Replacement: passo 2, immagine 2 di 3 Dell Inspiron 1521 DVD Drive Replacement: passo 2, immagine 3 di 3
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 DVD Drive Replacement, DVD Drive: passo 3, immagine 1 di 2 Dell Inspiron 1521 DVD Drive Replacement, DVD Drive: passo 3, immagine 2 di 2
    • Locate the 4 mm Phillips #1 screw next to the white padlock image that holds the DVD drive in place.
    • Remove this screw with a Phillips #1 screwdriver.
  4. Dell Inspiron 1521 DVD Drive Replacement: passo 4, immagine 1 di 3 Dell Inspiron 1521 DVD Drive Replacement: passo 4, immagine 2 di 3 Dell Inspiron 1521 DVD Drive Replacement: passo 4, immagine 3 di 3
    • Use a plastic opener tool to carefully pry the DVD drive out of its pocket on the side of the laptop.
    • Once sticking out, pull the DVD drive the rest of the way out with your hand.
Conclusione
Cal Poly, Team 15-47, Forte Fall 2012 Membro di Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 990
