Introduzione
In this guide, we will be showing you how to remove and replace the Hard Drive.
Parti
Nessuna parte richiesta.
  1. Follow the procedures in Before You Begin.
    • Follow the procedures in Before You Begin.
    • Turn the computer over.
    • Remove the four M3 x 3-mm screws that secure the hard drive.
  2. Slide the hard drive out of the computer.
    • Slide the hard drive out of the computer.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Remove the two M3 x 3-mm screws from each side of the hard drive bezel, then pull to separate the bezel from the hard drive.
    • Remove the two M3 x 3-mm screws from each side of the hard drive bezel, then pull to separate the bezel from the hard drive.
  5. Slide the hard drive bezel onto the NEW hard drive, then tighten the two M3 x 3-mm screws to secure the bezel to the drive. NOTICE: Use firm and even pressure to slide the hard drive into place. Excessive force may result in damage to the connector.
    • Slide the hard drive bezel onto the NEW hard drive, then tighten the two M3 x 3-mm screws to secure the bezel to the drive.
    • NOTICE: Use firm and even pressure to slide the hard drive into place. Excessive force may result in damage to the connector.
  6. Slide the hard drive into the hard drive bay until the drive is fully seated.
    • Slide the hard drive into the hard drive bay until the drive is fully seated.
  7. Replace the four M3 x 3-mm screws to secure the hard drive.
    • Replace the four M3 x 3-mm screws to secure the hard drive.
Linea Traguardo
Terrence15
Membro da: 18/12/2017
70.643 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 16
Tutti i Tempi: 80
