Salta al contenuto principale
Introduzione
This guide will show you how to remove the optical disc drive from your device.
Parti
Nessuna parte specificata.
  1. Place the laptop facedown with the battery facing you. Push the switch above the battery to the right and hold it in that position. Lift the battery using the grip on the top and remove it from its socket.
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Kit di riparazione per Android
    A new screen or battery is one kit away.
    Acquista ora
    Acquista ora
  3. Remove the JIS #1 8mm screw from above the upper right corner of where the battery was. Remove the JIS #1 8mm screw from above the upper right corner of where the battery was.
    • Remove the JIS #1 8mm screw from above the upper right corner of where the battery was.
  4. Pull the optical drive out.
    • Pull the optical drive out.
Conclusione
Ravon Williams
Membro da: 16/04/2018
169 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 80
