Introduzione
In this guide, we will be showing you how to remove and replace the Memory Modules.
Cosa ti serve
Loosen the two captive screws on the memory module/modem cover and remove the cover.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Remove the module from the connector at a 45-degree angle.
Align the notch in the module edge connector with the tab in the connector slot.
Slide the NEW module firmly into the slot at a 45-degree angle, and lower the module until it clicks into place. If you do not feel the click, remove the module and reinstall it.
Replace the memory module/modem cover and tighten the captive screws.
